If you were me, what's the next mod?
dont know what you got E4OD or the ZF-5 BUT either way if you dont have an aftermarket clutch or built tranny you should go there next after the gauges of course.
OR
i can work at the sugar coating factory like some on here.....go bigger man!!! big oil, fuel,h2e and ic...if you go this route please carry a camera and post the destruction pictures when you break down. sorry call it like i see it.
one last thing. you live in colorado your truck runs a little rich up there compared to most here with simialr mods elsewhere. I'd pay good $ to see your face after your next mod being a pyro and nothing else.
....i'd go easy on the go pedal!!!! your egts are through the roof while towing and you can easily push 40 psi without towing. i could bury my needle(boost) and only had 1's...gauges 1st and then you may wanna look at that turbo. depending on how much you've been beating on it..it wont take much more.
OR
OR
without guages, I drive really conservitive. the two's came cuz the injectors were shot, so guages were put on hold. I've had no problems yet and guages will be in before the next haul. With all that I should be ok.
guages this week, IC when I locate the parts, than ?
I think I'll end up fabbing all of it, I have all the available tools for it plus it'll make the project a little more interesting and rewarding. I looked oon Ebay and the cheapest thing I found was an IC for a 6.0L for about $400-$500
#29
What happens if you have stage II and don't have enough oil, I know the oil helps with firing the injector but if you do stage II's first will you do damage to the injectors or engine without enough high presssure oil. I know you won't get full potential out of the II's but I am more concerned about possible damage. Also I read a lot about Joey at TE on here but I can't seem to be able to find his website, does anyone have a link. Also does the modded 17* move enough oil for the demands of the stage II's
#30
