Need to covert to 134, have a few questions
Yes you can. Go to Autozone and rent the special tool, and it will come right off. Some of the clutches can be fixed also if they are slipping. Measure the gap on the clutch, it should be .014 to a max of .030 gap. If it's larger than .030, you can get the tool and take the clutch apart, take a shim out, and put it back together to close the gap.
There are a number of factors that could cause it to freeze, pressures need to be check to be sure, but yes, that is one cause, just as over charging can cause it to be warm.
I converted my '82 F150 years ago and although it worked fine, it always needed more freon. A mechanic told me one day that you need to replace the hoses also as the 134 will leak through the old hoses. So, I had the hoses replaced and haven't had a problem since. Also, the 134 does require different o-rings. The 134 will eventually deteriorate the original o-rings.
That is true that a new r12 hose or o-ring will not seal r134a very well, but they have found out a r12 hose or o-ring that has been in service and saturated with r12, will seal against 134a gas. If you replace a hose you do need to get a 134a hose or o-ring, but old r12 hoses are fine unless they do develop a physical leak for some other reason.
#28
#29
I know this is a old thread but didn't want to start a new one for a small question. I recently got a great deal on a refurb compressor and was just wanting to buy new hoses to go with the new accumulator, and evaporator to put a end to anymore possible leaks but saw there are In Plant charged systems and pre charged systems and it all boils down to whether or not i have a Manual Shut-Off Valve At Compressor. I've found i do have this valve but was wondering if i need it. All the auto part stores would have to special order the suction hose meant to attach to a system with the valve.
Can i just do away with these valves, what are they used for exactly ? It's just a 90 degree valve and the hoses meant for a non-valve setup have the bends to attach it directly to the compressor. I also noticed the liquid line going from the condenser to the evaporator is only shown for a Manual Shut-Off Valve (pre-charged) setup.
Thanks in advanced peeps!
REELNAUTI4U
General Diesel Discussion
02-14-2008 04:08 PM
