Need help!!!
Old May 26, 2010 | 07:41 PM
scotteastin's Avatar
scotteastin
Need help!!!
I have a 1995 F350 with the 7.5 460. Here is the problem. Over the last few months, it has been stalling at both high speeds and idle. I wait a few minutes and it starts right up. Over time, it is now not starting for about 8 to 10 hours. Here are the things I have done....New distributor, new coil, new ICM, new coolant temp sensor, new fuel pressure regulator, new fuel pumps and fuel filter. It has newer plugs and cap n rotor. I am really starting to get a little mad... Help please..
Old May 26, 2010 | 07:50 PM
F250351W's Avatar
F250351W
clean and check your throttle body, and may as well do the whole intake system. I use Sea Foam Deep Creep and it cleans it to almost new
Njdub's Avatar
Njdub
I'd pull a spark plug and see how it looks and also put a scanner on her and see what she's throwing then report back.
Edit: what the previous poster should be done.
Old May 26, 2010 | 07:54 PM
F250351W's Avatar
F250351W
[quote= Edit: what the previous poster should be done.[/quote]
huh? .
Old May 26, 2010 | 08:02 PM
Njdub's Avatar
Njdub
Lol whoops meant to say what the previous poster said should be done also.
quickie70's Avatar
quickie70
Check timing and check for vacuum leaks. Could be plugged cat too.
Old May 26, 2010 | 08:07 PM
F250351W's Avatar
F250351W
oh ok haha yeah i was runnin a Cat3208 and the pump/intake as messed up, and i just redid the whole thing except the pump, i had to remove the throttle stop screw and now its running like a beast
