'89 B2, manual trans going... HELP!
My friend has a '89 Bronco 2, and the manual tranny is about to go. Going down the road in fourth gear, you can feel it kinda slip out and go clunk every so often, unless you hold the shifter with your hand. In addition, it makes lots of noise. Also, there is a junkyard close to him with loads of good A4LD's. One I know of is in my old '86 Bronco 2. I know the guy that runs the junkyard, and could get it for a good price. How hard would it be to swap this into his '89? They are both 4x4. Any help is appreciated, as I dont know how much longer his will last.
Sounds like a lot, but heck, compared to mounting a 5.0 L into a Mazda RX4, that would be a walk in the park. Yes, My dad and I did put a 5.0L in a Mazda RX4. Top speed was about 90MPH, but keeping your head off the head rest until you got there was real tough.
Never timed it in the 1/8th mile, but am certain it would have done well.
We sold it before either one of us got ourselves killed in it.
Something else I heard, but have not verified...
I am told the A4LD main case has the same dimensions and bolt patterns at the bellhousing and the tail shaft as a C4. If this is true, then swapping a C4 for the A4LD would also be a bolt in after the bell and tail were mounted. The advantage is that the C4 was designed for an 8 cylinder (302 cu.in. or 5 Liter depending on how you look at it). The C4 is a bit more rugged than the A4LD, especially if you add an aftermarket shift kit and cooler.
I'm certain there are websites and information out there on this. If I run across information related to the swap, I'll post it.
Now...
For the dreamer in your friend, there are kits to mount a 5.0 in that Bronco...Kits to mount 351 Cleveland Heads to the 5.0 block...start out at about 400 HP with stock block and heads...bore and stroke, mill heads...Blower...Injection...and then try to keep the wheels from spinning!
You might be right about the computer.
Another reason to have the donor close by. Something I found out when I was working on my wife's '88... There were pieces of original wiring harness looped up and stuffed under the dashboard for optional equipment that wasn't installed. I bet if you do a little investigation, you might just find the wiring for the automatic already there (wouldn't that be sweet?). You would only need to "trade" computers...
Best if you call your local Ford dealer, and politely needle the service technicians for assistance. These days, dealers cannot afford to short change anyone for anything, and they know it.
I stopped at our local dealer often and spoke with them at length on different things. Stopping by the local donut shop on the way can result in the cheapest, best information transfer money can buy.
They'll actually look forward to your visits too. Call them first to see how busy they are, and time your visits to occur during slow periods.
IMO, any vehicle with a A4LD makes it to the junk yard when it goes and the people find out it cost $1400 for a rebuilt. Plus, if a motor blows (overheats), the A4LD usually follows in short order. A used A4LD is like putting a revolver to your head with three barrels loaded.
Think about this. Reading this board you know A4LDs have a tendency to not last as long as other transmissions. This guy has a load of good A4LDs. I suppose if I had a load of A4LDs that noone wanted, they might start to all look good too
I think you should find a good used manual from a BII (direct swap) or better a 4.0 Ranger (take the flywheel and starter) and skip the A4LD idea.
If you drive it an additional 30K miles, the mileage difference between the 5 spd (18+) and AT (15+) will be about 330 gallons of gas. Or $500.
The thing is when the A4LD goes, it will most likely be sudden and unexpected. At least when your manual goes, you can get by holding it into 4th gear or just changing the clutch. You know what I mean?
I did not see this mentioned.
It is noisy all the time.
Have you checked the fluid level???
Have you tried changing it (cheap $10) and making sure the vent tube is working?
