lowering a 65 f100
Old May 25, 2010 | 11:55 PM
Kirbys73F100's Avatar
Kirbys73F100
lowering a 65 f100
Hey guys, I have a 65 f100 I bought for $300 a few years back. It has a 429 and c6, runs and drives. Had some body work done to it by previous owner and is sprayed with red oxide primer. Id like to maintain a rat rod look as well as spend the least amount of money possible as I am building a 79 250 on rockwells and 53s too. The local pull a part sells leaf springs for $10 a piece and coils for $10 a piece. My question is, what year trucks can I pull leaves and coils out of to fit this truck. Id like to set aside the stock suspension so I can put it back to normal but take a leaf or two out of the junk yard springs and heat up the junk coils for a couple cheap, very temporary inches. Any info would be appreciated!
Old May 26, 2010 | 06:07 AM
ddavidv's Avatar
ddavidv
You CAN NOT lower a Twin I Beam truck with springs. It ruins the camber. You have to buy or fabricate drop beams.
Old May 26, 2010 | 08:24 AM
Kirbys73F100
Thanks for the warning but I knew this. I'm still going to because I'm running scrap tires on it. It's only temporary though.
Old May 26, 2010 | 09:35 AM
garbz2's Avatar
garbz2
It appears you all ready have the answers.
Garbz
Old May 26, 2010 | 02:22 PM
Kirbys73F100
Garbz
If I had all the answers, I wouldn't have bothered you good folks with my original question. But it's obvious you didn't read that part.. Thanks though!
Old May 26, 2010 | 07:23 PM
Hotrodded66f250's Avatar
Hotrodded66f250
I am going with the same rat rod theme as well with my 66 f-250....but mine will be primer black with a white roof. I heated my front coils and dropped it almost to the bump stops....it has a little bit of camber but nothing that bad. I want to go lower so I might try moving the pivot points up an inch or whatever I got room for and then drop the coil a bit more. I find it rediculous with how expensive drop beams that I will never buy any! For the rear I just pulled 4 leafs out of the pack and Im gonna run a drop shackle...looks great and still rides down the road pretty well!
Old May 26, 2010 | 08:38 PM
F&M's Avatar
F&M
I was always told if you heat a spring you ruin it.Although I think you can cut shorten one with a torch,but if you get it red hot to re-shape it somehow...well...then I'd rather be in the vehicle AHEAD of you on the road! Garbz..your voice of experience please.
Old May 26, 2010 | 11:08 PM
Kirbys73F100
Thanks for the info guys. What year trucks can I pull coils out of at the junk yard to put in the '65?
Old May 27, 2010 | 09:58 AM
sgreen's Avatar
sgreen
Smile just answer the question...
half ton ford coils up to 79 should fit your truck. Take a tape measure to the yard and measure the leaf springs there for help on that.
Old May 27, 2010 | 12:26 PM
Flyn66dtmn's Avatar
Flyn66dtmn
FWIW- i built my own jig to adjust the camber in my trucks , works fine. i lowered the front on one of them and bent the I-beams to do it. i might add here that it prolly wont work if you get radical with the lowering to much. may wanna get the drop axles then. i only lowered mine about an inch and a half and i could tell that my homemade jig prolly would not have handled more of a bend. it's to bad they dip the drop axles in gold when they make them. also fwiw. i did notice some wear on the inside of one tire after about 6000 miles. this is due to not having the proper alignment equipment that a alignment shop will have. one shop wouldn't even do it and the other said 400 bucks and didn't even go out and look at it. so there's the down side of doing it your self. Dutch
Old May 27, 2010 | 02:38 PM
garbz2's Avatar
garbz2
You can remove a coil by cutting with a chop saw. Heat destroys the spring and changes the weight rating. However the camber must be reset to stock.
As to the camber being off it is a big deal. Not having it correct will lead to excessive loading of the upper bushing and failure and excsessive wear of the steering components. It is why there are no cheap and easy ways to lower stock beams.
One must also remember to not cut springs with aftermarket beams as there is ZERO camber adjustment avalible in them as they are fabricarted pieces of junk.
Garbz
Old Aug 20, 2010 | 10:56 PM
mdacton's Avatar
mdacton
I cut my coils and flipped the rear with 90's model flip brackets from djm and I did some minor work to tmake them fit.
I know it isnt the propper way to do it but I dont care
Old Aug 21, 2010 | 08:05 PM
LBF's Avatar
LBF
Cut springs
My '65 F250 came with cut front springs - when the front end was jacked up to pull a wheel to check the brakes the springs fell out. Not a good thing to have happen.
Old Aug 22, 2010 | 12:59 PM
garbz2's Avatar
garbz2
The first person that you have an incident with, their attorney will care.
Garbz
Old Aug 22, 2010 | 02:52 PM
mdacton's Avatar
mdacton
Garbz
probly not
