Head Gasket
Old May 25, 2010 | 07:27 PM
david00f150's Avatar
david00f150
Head Gasket
Im swapping heads on my 302 and put a set of ported E7's on it. They have been milled 10 thousandths. Do they make a gasket thick enough to compensate to keep the compression ratio stock?
Old May 25, 2010 | 10:45 PM
Conanski's Avatar
Conanski
Don't worry about compression it won't change enough to affect anything, but you will need 10thou shims for the rockers to get factory preload on the lifters.
Old May 27, 2010 | 04:26 PM
david00f150
I found these two kits at summit racing. Either one would work if I combined the two shim sizes right? They would equal 9 thousandths (.090) but I figure thats close enough.
SummitRacing.com
Old May 27, 2010 | 05:48 PM
Conanski's Avatar
Conanski
No those are 30 and 60 thousandths shims.. you don't need that much.
Old Jul 14, 2010 | 05:23 PM
david00f150
I cant seem to find 10 thousandths shims. Can anyone help me out?
Old Jul 14, 2010 | 09:21 PM
Conanski's Avatar
Conanski
10 thou may not be enough to worry about in terms of rocker preload, but thicker head gaskets are available to take up the slack in any event, even Summit has various options.
