Sponsored by: Real Truck
99 7.3 wont start.
Old May 25, 2010 | 05:08 PM
acfrump58's Avatar
acfrump58
99 7.3 wont start.
OK. Here is the situation, had a small leak coming from the HPOP changed all the o-rings, drove it down the road and everything looked good. once I started cleaning up my tools I found a small key stock looking piece which was said to be a restrictor.
so now I had to tear everything back out and put that piece back in. In the process of putting everything back I broke the threads for the pressure relief/fuel return on the side of the fuel filter bowl. I put everything back except that now that I have also fixed that my truck wont start.
Cranks and cranks but will not fire, no smoke out the pipe, have bled the fuel lines at every connection I can find and the oil pressure gauge in the dash shows good pressure. Any Ideas, thanks.
