'92 f150 6cyl, fuel pump runs constantly (intermittent)
on
on
I think we have a communications fault...I understand all of that, and where it is...what I was saying is that the relays I took out of it are not colored like your describing...I'll try and take a pic to show u what I mean. I went to ford and got tan eec relay, and ordered the f/p relay...I looked at it before I left and told him it didn't look right and it wasn't going to fit, but he said it was the replacement for the old one but it doesn't even look close to what I took out, so I told him i'd give it a go...probably look at it tomorrow
on
I put up pics of the fuse box in the engine bay, and a pic of the relay I took out and what they gave me. https://www.ford-trucks.com/forums/p...ictureid=36000
on
Here's mine! PCM/FP Relays picture by ymeski56 - Photobucket
Do you have an electric cooling system &/or A/C?
I don't see any relays pictured!
the inside of the cover just says relay 1 thru 5, and calls out wether its a maxi fuse or STD, or diode. You have to look in the owners manual to find out what each one of them is for, and their amperage. Yes I have A/C, but i dont use it cuz its not cold...those fuses are in the cab by the steering wheel. I pulled the relays out to take the pic...and i took a pic of the relay I took out, and the one ford sold me...i put 3 pics in my album, did you see those?
https://www.ford-trucks.com/forums/p...ictureid=36001
i guess it only linked to the pic, not the album...these are the relays
#28
on
#29
the third is just a pic of the truck. Well I'll work on getting the relay situation straightened out, as I said before the 3 relays I pulled out were for the horn, f/p, and the EEC...they were all the same..which is apparently wrong for the f/p and the eec, so when I replaced them all I did was replace them with the wrong ones. I went to a junkyard today but they closed at 12.
My work schedule is all jacked up right now with 16 hrs of O.T./week and my only day off will be sunday till june 24, so its probably gonna take me awhile. I'm looking for all of the ground points and cleaning them up right now...its hot as hell and it sucks!
