Jammed door lock
Old May 24, 2010 | 08:23 PM
zhilton's Avatar
zhilton
Jammed door lock
I did a little searching in this forum...but didn't find what I'm looking for. My wife's '01 Explorer....the driver's door doesn't always unlock when you use the keypad on the door...or the FOB. If you tap either two times it usually will unlock. If using the key, it's difficult to get the lock assembly to turn. We're running the OEM keys, so I know it's not an error with the key. I'm assuming this is the actuator in the door getting old that to blame for the FOB/key pad issue?
Secound, and a little more important...the rear door on the drivers side the lock acts like it's jammed. I managed to get the door open by working the plunger at the top of the door panel...but it still jams when you lock the doors. I took the panel off (after making sure the child lock wasn't on) to see if I could see something a-miss. Nothing looked wrong, the plastic handles are in good shape and both springs are there. I went ahead and put some penetrating oil on the latch thinking something was in it...but that didn't help. Is there a spring or something that I might be missing???? Thanks in advance.
Old May 24, 2010 | 08:38 PM
mwkobe's Avatar
mwkobe
i fixed similar problem for me it was the latch assembly that need replacement here a link to the problem
https://www.ford-trucks.com/forums/7...ring-help.html
Old May 25, 2010 | 08:18 PM
zhilton's Avatar
zhilton
I didn't see any springs loose in the door. Is there one somewhere other than the backside of the plastic handle? It will be this weekend, but I can try to tear the door back apart and look again.
Old May 25, 2010 | 09:44 PM
mwkobe's Avatar
mwkobe
the spring actually breaks inside of the latch there is a thread on here that talks about fixing the spring but i just bought a new latch assembly
wayne
jamnjm
Oct 10, 2016 01:34 PM
user 708242442
2015 - 2020 F150
Jan 22, 2016 08:23 AM
donjamer
General Automotive Discussion
Nov 1, 2015 07:14 AM
powerstroker100
Jul 10, 2015 01:18 PM
limerence
Feb 12, 2015 09:53 AM
