390 with 427 heads?
Old May 24, 2010 | 04:16 PM
73FordF100's Avatar
73FordF100
390 with 427 heads?
Is this possible? Right now I have a 360 in my truck and one day I hope to build it to a 390. When I was thinking about this, I was toying with the idea of building it to a 390 with 427 heads. I think its possible because it's in the same FE engine family, therefore having the same engine block? I know the heads for a 427 are very expensive but they may be worth it performance wise, if it's possible to do this. Any advice would be helpful. Thanks guys.
Old May 24, 2010 | 04:24 PM
85e150's Avatar
85e150
Go to the FE forums and read up. You need not search out expensive "427 heads" for your 360. D2-- heads found on many 360s are fine, and can be ported and cleaned up to support a 390 or 410 or even a 445 just fine.
You can find many threads on "fixing" the 360, one way or the other, in that forum as well.
Old May 24, 2010 | 04:29 PM
73FordF100's Avatar
73FordF100
Ok thanks for the info! I will read up! I don't really know that much about my 360 heads as you can see, but i'm learning!
dadstan76
Aug 15, 2009 05:31 PM
rebelman108
Dec 2, 2008 10:48 PM
tylstruck
Feb 2, 2008 04:36 PM
actioncam1
Dec 8, 2005 04:53 PM
Huntersbo
25
Sep 24, 2005 01:31 PM
