A/C Clutch gap 2003 Navigator
Old May 24, 2010 | 02:49 PM
fixit5561's Avatar
fixit5561
Hey guys,
I am going to replace the ac clutch on my Navigator.
I searched on FTE and couldnt find anything about the gap on the Naviagtor.
Is the clutch gap supposed to be the same as most I have search and read about? That is I have seen where on most Ford's the gap should be around .030.
Thanks for your help
Brian
Old May 24, 2010 | 07:34 PM
projectSHO89's Avatar
projectSHO89
See FAQs above.
Old May 24, 2010 | 08:45 PM
fixit5561's Avatar
fixit5561
Thats project SHO,
I have tried FAQ, I tried: ac clutch gap, nav ac clutch gap, and a bunch of other combos of the words and searches searches and I cant find anything for the navigator. Also it keeps coming up with sorry no matches.
Im stumped for sure! LOL
Old May 24, 2010 | 09:27 PM
lsrx101's Avatar
lsrx101
.030 is a bit wide, I'd try for closer to .015-.020.
The actual gap isn't critical, you want it as narrow as possible without rubbing when the clutch is disengaged.
Old May 25, 2010 | 05:59 AM
projectSHO89
Originally Posted by fixit5561
Thats project SHO,
When I wrote the FAQs two years ago, I put it in there. It is STILL in there...
Old May 25, 2010 | 07:04 AM
fixit5561's Avatar
fixit5561
Thanks project SHO, lsrx101
Yes I did see the FAQ you were talking about SHO.
I also read on the forum that: "Normal clutch gap is 0.014-0.030" (But that does vary slightly by model)".
So I figured I would ask what my specific vehicle's gap was. It just seemed that (this is from just gapping plugs all my years) 0.014-0.030 was a large margin of error much more larger than what a spark plug requires.
So reading the above quote and knowing plugs are gapped with alot closer tolerances, I was asking what my specific vehicle's gap tolerance was. Thats why I had asked for the specifics. Maybe I should have been more specific, but was at a loss for words (brain farts is what I call it LOL) when I wrote my post above.
Old May 26, 2010 | 08:59 PM
dstig1's Avatar
dstig1
It's a large range because it is a clutch disc - a wear item. They generally start out at the tight end of the range, and then will still work after a fair amount of wear (until about 0.030"). Most models are in that range, at least for Ford. If you get about 0.015-0.020" after readjusting, you should be good for a long time.
-Dave
Old May 26, 2010 | 10:12 PM
fixit5561's Avatar
fixit5561
Hi Dave,
Thanks again, I got it around .018 around the clutch so it works great now. Couldnt have done it without all you guys help. Thanks a bunch!
Innocent Bystander
May 12, 2015 11:53 AM
dn29626
Jun 2, 2013 12:41 AM
dad2bandm
13
Nov 8, 2012 10:11 AM
jh818
Jul 11, 2012 08:57 AM
reignman
Mar 15, 2007 08:53 PM
