transmission conversion ?'s
Old May 23, 2010 | 10:53 PM
broncoguy83's Avatar
broncoguy83
ive got an 83 bronco with a 351 windsor in it. the original drivetrain set up was a borg warner t-18 and np208. i yanked that out and now im going to be running my 351 backed by a 1970 wide ratio top loader. ive already got my clutches picked out and how to mount it in there but i need a place to look for some sorta clutch linkage set up from ground up, when i got the top loader it just came with the bellhousing for a small block. any good places for cheap easy clutch linkage kits?
Old May 23, 2010 | 10:54 PM
broncoguy83
i forgot to add the reason i went from 4 wheel drive to two wheel is because im making it a prerunner
