battery light?
Old May 23, 2010 | 08:59 PM
MissIndependent's Avatar
MissIndependent
battery light?
so, miss trouble has decided my reprieve is over...she is tired of behaving nicely. i was kinda enjoying the 3+ month run with zero issues beyond not having enough money for fuel : P
my battery light has started coming on while driving- specifically when i put the brakes on. it goes away (flickers and fades out) when i accelerate. her batteries are less than 6 months old. new starter as well. the battery gauge shows a strong charge once the glow plugs go off.
so...alternator?
and on a tangent...how do i replace the light bulb behind the tach and speedo? it's been out long enough i gotta stop griping about it and just fix the damn thing lol...once i hit od i'm only guessing at my speed in the dark!
Old May 23, 2010 | 09:08 PM
Talyn's Avatar
Talyn
you gotta pull the dash cluster out to change the bulbs.
I can explain it to you over the phone easier.
you need a t-15 driver, or some small socket size i cannot recall at the moment.
Old May 24, 2010 | 08:01 AM
wmiller's Avatar
wmiller
Try checking the plug on the top of the alternator. They have a habit of rubbing the coating off of the wires
Old May 24, 2010 | 08:46 AM
Jim Hunt's Avatar
Jim Hunt
$200 alternator and 10 minutes fixes that problem
Old May 24, 2010 | 08:25 PM
paddler's Avatar
paddler
Dash lights
Can be a PITA... have to pull the instrument cluster. Replace all the bulbs, and do any wiring back there while you're at it.
The two tricky parts are getting the **** off the main light switch and, for autos, pulling the gear indicator cable off the little stud on the needle mechanism.
The first screws to come out are hidden behind the little trim bars on the dash panel. The trim bars pry out fairly easily. After that, it's reasonably obvious, if tedious.
Old May 25, 2010 | 01:39 PM
MissIndependent
thanks guys...3 day weekend to get it done...after the strawberry festival of course
MissIndependent
william i will call you later in the week
whimsy
29
Sep 28, 2016 05:44 PM
deputydog03
81
Mar 8, 2016 09:20 PM
deshet1980
Jan 5, 2016 05:15 PM
eman588G
Jun 11, 2015 02:06 PM
Bigboy99
Feb 24, 2014 09:51 AM
