Questions about headlight installation
Old May 23, 2010 | 08:25 PM
tractorfan's Avatar
tractorfan
Hey guys,
I got me a set of 02-04 headlights to replace my old 99-01 lights. How difficult are these to replace? I also picked up some oem fog lights. Will these mount on my truck that did not originally come with fogs? I tried to search the forum for answers but keep getting errors. Thanks in advance.
Old May 23, 2010 | 08:31 PM
F350-6's Avatar
F350-6
The headlight replacement isn't too bad. The turn signal lights just remove some screws below the lights. Remove the wiring from the headlight and it pulls out (takes some pulling sometimes).
The foglights will likely be more tricky. Unless your headlight switch will pull out 1/4" when you have the headlights on, you'll need a new switch and to play with some wires to make the fog lights work. I changed out the headlight switch and tapped into a wire to make my fog lights work.
Old May 23, 2010 | 08:39 PM
jbounds's Avatar
jbounds
There was a thread on this not too long ago...a total breakdown on how to install them..... https://www.ford-trucks.com/forums/9...te-how-to.html
In his thread though he didnt take out the up and down adjuster....to remove it I used a 9/16" socket on the backside where the tabs are...wiggle it around a little bit and it will pull right out....Its alot easier than I tought it would be to put them in.
Hope this helps
Old May 24, 2010 | 07:26 AM
tractorfan's Avatar
tractorfan
Thanks for the help guys. I have them installed, but the right side headlight is a little loose. What could be wrong? Also do I need to remove the bumper to install the fog lights? Thanks.
Old May 24, 2010 | 09:53 AM
jbounds's Avatar
jbounds
Im not sure about the fog light question I didnt put those on my truck....but with the headlight just make sure the adjuster slid in where it was suppose to and make sure those two clips that hold the headlight in are tight and didnt pop off...if it where my guess though i think it might have to do with the clips.
Old May 24, 2010 | 12:30 PM
tractorfan's Avatar
tractorfan
I went out and double checked. The clips are on correctly and the adjuster is in correctly also. The lights have a bit of side to side play to them.
Old May 24, 2010 | 12:36 PM
jbounds's Avatar
jbounds
The only thing I can think of is the clip that holds that adjuster isnt tight but like you said they are on correctly but im stumped now.....
