fuel pump????
Old May 23, 2010 | 05:58 AM
fordktpjoe's Avatar
fordktpjoe
fuel pump????
So yesterday I went to take the carburetor off so I could remove that rusted off tube that runs from the EGR plater to the AIR pump, and when I broke the fuel line loose, it just kinda sagged, I figured it should have been held in place, being a bent steel line from the fuel pump to the carb.
So I lean over to have a look, and guess what? No fuel pump on the side of the engine! the line just runs down, into a rubber line, then back to steel and disappears down the frame rail.
I'm scratching my head... 1984 4.9L supposed to have mechanical fuel pump, right?
According to all the auto parts store websites it is, but apparently mine's not.
What gives? electric fuel pump on a carbed truck? Or just some weird mid-year change hybrid?
Looks like it ain't gonna be fun if I ever have to buy a pump.
Any ideas/answers?
Thanks, Joe
Old May 23, 2010 | 07:18 AM
ctubutis's Avatar
ctubutis
Assuming you ARE supposed to have a mechanical pump, probably a previous owner
changed to an electric pump. Crawl under there and trace all the tubes and wires and see
where they go to determine what you have; there's no end to the mods that have been
made by people on these things over the course of 25-30 years.
Old May 23, 2010 | 08:47 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is there a block off plate on the timing cover where a fuel pump would have bolted on?
Certainly you need a flexible connection between the engine and chassis.
Lots of 460's have electric pumps and a carburetor. It's known as the 'hot fuel handling' option and circulates fuel past an orifice that returns fuel to the tank.
This is an effort to reduce vapor lock.
Sorry, I don't know much about I-6's other than they are torquey, have timing gears and seem to last forever....
Old May 23, 2010 | 09:56 AM
JimsRebel's Avatar
JimsRebel
Any ideas/answers?
Thanks, Joe
The change occurred in 87 with the change to EFI. The EFI blocks cast over the hole where the fuel pump mounted, so no hole for the fuel pump would mean an EFI block.
<O</O
Do you have dual tanks?
The electric fuel tank selector is on the frame rail just forward of the front tank, which would be a good point to mount an electric fuel pump, on the output of the selector.
Jim
Old May 23, 2010 | 05:02 PM
fordktpjoe's Avatar
fordktpjoe
<O</O
Jim
Only got one tank.
Hard to tell if the F/P hole is blocked off, or just has a plate covering it, that monstrosity that holds the TFI coil is bolted right there. I'll get a pic.
Old May 23, 2010 | 05:20 PM
fordktpjoe's Avatar
fordktpjoe
Apparently at some point Ol' Red had a heart transplant. The fuel pump mount isn't drilled/machined to accept one...looks like I got a later model block.
Old May 23, 2010 | 05:25 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So now the question is how did the P.O. wire it into the older harness and did he scavenge the factory pump setup from the donor truck...
Great pic's BTW. I'm really interested in learning about how all these trucks were set up.
Thanks.
Old May 23, 2010 | 05:47 PM
ctubutis's Avatar
ctubutis
Thanks.
Factory shop manuals are GREAT for that.
Old May 23, 2010 | 05:54 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have some on CD but it's just not as rewarding looking at a screen as it is when you're out under your truck thumbing through grease stained pages.
