whats wrong with my e40d?
Old May 23, 2010 | 02:19 AM
fordinmudd's Avatar
fordinmudd
Question whats wrong with my e40d?
My truck is a 94 f 250 4x4 with 120k with a e40d tranny.The tranny will shift to fast about 4 times a day it does this fast and hard then it stops then the tranny is fine.It seems that its only one of the gears doing this as it does it only around 15 to 20 mph.it doesnt really slips it shifting to fast and hard sometimes .I was thinkign if i bring it to a tranny shop now maybe it will be cheaper then waiting any longer.anyone know why it would be doing this?also the truck has a snow plow on it.the guy i bought it from was a landscaper so who knows what he did to it.what would be causing this hard and fast shifting 4 times a day?any info will help thanks.
Old May 23, 2010 | 02:42 AM
Towmanjbo's Avatar
Towmanjbo
Certainly sounds like the MLPS (Manual Lever Position Sensor), a common part to wear out.
Old May 23, 2010 | 09:40 AM
fordinmudd's Avatar
fordinmudd
thanks for the info I will look into it.thanks again.
Old May 23, 2010 | 09:57 AM
fordinmudd's Avatar
fordinmudd
just wondering if thats what the problem is what would a tranny shop charge me to fix this?
Old May 23, 2010 | 04:00 PM
mike93's Avatar
mike93
here's one, the computer may think you are in 4x4 low. Is your 4x4 light illuminated on the dash? The shift schedule in 4x4 low is very firm and fast shift timing, all 4 gears by 25mph. After you check your MSLP check the sensor on the T-case. It does need an aluminum seal washer between it and the case.
Old May 27, 2010 | 02:17 PM
fordinmudd's Avatar
fordinmudd
no the 4x4 light is not on when it does it.
Old May 29, 2010 | 02:44 PM
Towmanjbo's Avatar
Towmanjbo
I guess you'd have to ask them. For what it's worth, I fixed mine in the driveway in about an hour. It's a small external part.
csmith30005
Aug 12, 2016 03:40 PM
danman_83
Nov 4, 2015 12:32 PM
IcutMetl
Aug 14, 2012 07:48 AM
southcoast
Jun 8, 2011 02:03 PM
winchcable
13
May 15, 2008 12:40 AM
