glow plug timing problem please help im clueless
Old May 24, 2010 | 08:11 PM
powerstroker100's Avatar
powerstroker100
Originally Posted by David85
This is the wiring diagram for your era of glow plug system (actually thats also most of the engine harness right there):
What is shown in the picture that Rupe posted earlier is the glow plug controller. The controller has a built in relay on it so that is the complete controller assembly.
The light coating of oil is normal. Diesels have a system similar to a PCV system on a gasser, and small amounts of oil vapor ingested by the intake is a simple fact of life. Nothing to worry about unless you start seeing large amounts of oil consumption.
yes where is the crank case ventilation on this truck, on the 6.0 it was right on the right valve cover I'm not farmiliar with pcv, but that aside, this is what I just did I took multimeter and tried testing the top two prongs of the relay truck was off I'm not sure if it matters but the one to the right read same as my battery voltage but the left one read zero I had it set to AC volts positve on battery ground on relay, does this mean I need a new relay and controller?
Old May 24, 2010 | 08:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
this means you didnt read the thread i directed you to.
hey,i love that rig.cant wait for the couple more pics you said where coming.
Old May 24, 2010 | 09:43 PM
powerstroker100
sorry I will go back to the link, I did skim through it though, as for the pictures I will have them coming, on other news I did the soupbowl mod today! haha
Old May 24, 2010 | 09:46 PM
powerstroker100
OH also I forgot about this, I tried to lift the caps off of the glow plugs I only gave them a tiny tug and it wouldnt come off so I got scared and left it alone, I read about people who tried moving them and lifting them out,etc. and they broke and fell into the head? is this possible, because otherwise I don't know how to grab em, should I just go hercules and see our end result?
Old May 24, 2010 | 09:50 PM
PLC7.3's Avatar
PLC7.3
Re the intake oil..... if it is dripping off the hold down bolt then check/clean the CDR valve.... I will PM you some info and my email addy so I can send pics ect if you respond. The GP wire end covers are plastic they will crack and fall off..... "not into the head" You can get heat shrink tubing and replace the plastic with 2 coats..... leaving a slight amount beyond the tip......
If there is no reason to remove them leave them ......... However if you need to test the GPs pull on the end only not the wire.
Old May 24, 2010 | 09:53 PM
powerstroker100
would be most appreciated thanks PLC7.3
Old May 24, 2010 | 11:02 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Disconnecting the wires from the glow plugs can hurt nothing but the harness or maybe glow plug terminals.
I assume the '93 in your sig, it has the bullet connectors and they just pull off.
What you are worried about happens when the wrong glow plugs (other than Motorcraft/Beru) are used, sometimes the tips swell and break off falling into the cylinders.
-Enjoy
fh : )_~
Old Nov 6, 2010 | 06:17 PM
Lguapo's Avatar
Lguapo
I'm glad you guys know what your doing cause I changed the fuel pump the fuel/oil separator the glow plug relay the glow plugs I've aired out everything and NOW for the last thing the CONTROLLER!!!!! I would be mad but on the bright side I now have everything updated and new!!!!
Weeks7524
Dec 18, 2015 11:28 AM
Codyscee
Modular V10 (6.8l)
Aug 27, 2014 03:39 PM
mnc87
21
Aug 11, 2014 06:07 PM
mrwrench
Jun 2, 2014 09:15 PM
thebeast150
Aug 5, 2010 03:09 PM
