5-speed transmission
Old Feb 22, 2003 | 01:20 PM
mk's Avatar
mk
Ken, what driveshaft/ mount mods were necessary to do this swap?
Old Feb 22, 2003 | 07:44 PM
badboyina67's Avatar
badboyina67
Driveshaft was shortened...took it to a place that did it.
Rear tranny mount moved back...very easy to do.
Ken
Old Feb 22, 2003 | 10:07 PM
F100PxDriven's Avatar
F100PxDriven
Wow, that's some good info, Chris, thanks. I was wondering though, in your '70 F-100, what transmission are you using? You said you get 1900rpm at 60 mph, I was just curious. Thanks
Anthony
Old Feb 23, 2003 | 09:46 PM
cseay1's Avatar
cseay1
Anthony -- I'm sorry I guess I wasn't clear in my post -- I have a 9" rear end OUT OF A '70 F-100 in my '49 F-1 . . . I guess the rest of the '70 F-100 is still in the junkyard or has been long since recycled into shovels, rakes, and implements of destruction!
chris seay
bealeton, va
'49 F1s
'68 F100
Old Feb 24, 2003 | 10:13 PM
BlueRanger94's Avatar
BlueRanger94
When you use the M5OD what do you use for a clutch pedal. Did you use the F150 assembly? If not what did you use?
Thanks
Old Feb 25, 2003 | 06:39 AM
badboyina67
I used the stock pedal in my '67 and the hydraulic clutch set-up from the 1990. If you remove all the rods from the original (67-72) set-up, it's as easy as cutting, welding, drilling and bolting. I have the whole thing in my head...let me know if ya need the info. It's really quite easy to do.
Ken
68Ford4Life
23
Apr 22, 2017 06:52 PM
Scottmcp5
Sep 2, 2014 01:12 PM
Justin Jones
Apr 8, 2014 10:25 PM
ceetwarrior
28
Apr 28, 2013 03:25 AM
urban87_cowboy
23
Jan 12, 2013 06:48 AM
