5.4 Internal engine question
Old May 20, 2010 | 05:02 PM
jackndelphine's Avatar
jackndelphine
Hi, I hope this isnt a stupid question but here goes...I'm in the process of replacing the crank, rod and main bearings due to a rod knock....I have only one problem...I took out all the main cap bolts in order to remove the bearing caps to get the crank out, and I can't get the caps off, I noticed the pins on each side of the bearing cap and I'm guessing they have to come out? If so, how do I get them out? As for working on a 5.4....this is a first for me, I'm an old school truck guy but I am helping out a buddy of mine....any help or tips you guys could offer would be appreciated. Thanks, Jack
Old May 20, 2010 | 09:17 PM
70f100longbed's Avatar
70f100longbed
There are bolts on both sides of the block that goes through the pins into the caps.
Old May 20, 2010 | 10:37 PM
jackndelphine
Oh geez, well it was pretty late last night, I was trying to work a little late to be able to turn in the crank to avoid a core charge, I guess it was kind of a stupid question, I should have look around a little more, well thanks for the info, I thought I was losing it...lol. I gotta go pick up the book by George Reid, I have never worked on a modular engine b4. Thanks again, Jack
Old May 21, 2010 | 07:36 PM
70f100longbed
No problem. If you have any other Qs just ask. I dont mind giving advice.
Driver Jim
Modular V8 (4.6L, 5.4L)
Aug 17, 2014 09:02 PM
RydeMyToy
Modular V10 (6.8l)
Dec 16, 2013 03:47 PM
jackndelphine
Apr 27, 2011 03:41 PM
John Scruggs
Apr 21, 2011 04:31 AM
duck head
May 12, 2007 01:38 AM
