Is this a good setup???
Old May 19, 2010 | 11:39 PM
whatthencuz's Avatar
whatthencuz
MSD 6420 6AL Ignition Control Box with Rev Control
Ford 351W Windsor SBF Ready to Run Distributor
<a href="http://cgi.ebay.com/ebaymotors/SBF-FORD-289-302-351W-FUEL-PUMP-HIGH-VOLUME-1007-C-/370353532389?cmd=ViewItem&pt=Motors_Car_Truck_Part s_Accessories&hash=item563aca6de5">SBF FORD 289 302 351W FUEL PUMP HIGH VOLUME 1007-C</a>
Its going in a 351w (yr uknown) has ford racing cam (size unknown), offenhouser intake, 3 angle valve job, its going to run on a 1406 600 cfm edelbrock carb, long tube headers, and I am going to use an Accel 8140C ignition coil and Ford Racing 9mm spark plug wires. Does that sound like a good setup? Also, what kind of spark plug is recommended? Any input is welcome.
Old May 20, 2010 | 10:02 AM
Conanski's Avatar
Conanski
Sure.. that'll do the trick. I'd advise against putting any money into stock heads though, they're simply too small for this displacement so at the very least consider purchasing a set of CNC ported E7's from Thumper or PowerHeads.
http://thumperoforangepark.com/
Power Heads - Performance Engineering
Old May 22, 2010 | 02:35 PM
Old Hickory's Avatar
Old Hickory
Thanks for those links Conanski. Very good info.
