Slip Yoke?
Old May 19, 2010 | 08:17 PM
RangerHaywood's Avatar
RangerHaywood
Slip Yoke?
Isnt this called a slip-yoke? If so, is it supposed to be extended this far?
http://sphotos.ak.fbcdn.net/hphotos-..._3803539_n.jpg
Old May 19, 2010 | 08:43 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Well, it's not exactly a slip yoke. But, no, it should not be extended that far.
Old May 19, 2010 | 08:53 PM
RangerHaywood
ohhhkkkk why is it extended that far and how should i fix this?
Old May 19, 2010 | 09:08 PM
HillbillyDeluxe81
Well, it looks like someone installed a lift and did not extend the driveshaft. If the splines are still tight, you can have the drive-shaft extended. But, the splines are probably worn. In that case....you should probably have the shaft rebuilt.
Old May 19, 2010 | 09:19 PM
RangerHaywood
Ohh thats awesome.....grr....
Old May 19, 2010 | 09:28 PM
HillbillyDeluxe81
With the truck in neutral, and no load on the driveshaft, can you wiggle it side-to-side??
Old May 20, 2010 | 01:32 AM
75F350's Avatar
75F350
Did you not ask at one time about divorced transfer cases? Do you know that this transfer case that you have a pic of is the most desirable case available?
Did you buy a truck already?
This pic is of a 10 spline shaft that has reached its limit. It appears to be a 1330 joint and unfortunately the splines are so dirty, that I cant see this thing working well.
That thing is nasty. It could use some help, and it could use a longer driveshaft.
Old May 20, 2010 | 05:52 AM
RangerHaywood
No i didnt ask about divorced transfer cases, but i did know that is the most desirable t-case ever built and I heard they were absolutely bullet proof too. What i was wondering is where and how much can i get a longer driveshaft?
