05' v10 F250. I have noticed lately that it takes more cranking time to start the engine. It dosent sound like the cranking speed is any slower. Any ideas?
Well I tried the lights on thing and saw no difference. It idles fine. The truck has 73k on it. I also have tried leaving the key ON before cranking....no change.
My first thought was the crank position sensor, I have heard this causing starting problems on other vehicles. Oh the fuel filter has 8k on it.
Might also try disconnecting the battery for fifteen minutes. Also, if you have cruise control, leave the sensor on the master brake cylinder disconnected.
Change the plugs if you haven't already. Be ready for a fight-they've been in there long enough to get somewhat stuck,but not to the point of impossible like it would be if they were at their recommended 100K mile service interval.
JL
