Got to love AC problems
Old May 19, 2010 | 07:12 PM
ciscofreak's Avatar
ciscofreak
So I have a visible pinhole leak in one of my AC lines that runs from front to back. I have a call in to Ed to give a price on all the lines. Nothing like corrosion to ruin your day....
Old May 22, 2010 | 11:56 AM
chazman's Avatar
chazman
I just put in a splice pipe 5/8"ID and some clamps and recharged it. But it was the low pressure line..Not sure if it would hold on the high pressure side.
Old May 23, 2010 | 11:03 AM
dadsexcursion's Avatar
dadsexcursion
Speaking of AC. maybe you know about it. mine 05 V10 6.8 keeps pulsing on and off. Told so comp wont burn out. recharged with one can and still does same. air does not get cool. should i try another can. no leaks that i can see. what do you think?
rich
Old May 23, 2010 | 12:30 PM
bsm2003's Avatar
bsm2003
If you have to add refrigerant to the ac then there is a leak. These systems are sealed. The main place to look for and test with a soap solution would be compressor seals between pulley and comp. on the passenger side wher the evap is where hoses are bolted on. I had a leak there got it fixed and the place added som dyed refrigeran to my ac so if I have another leak I should be able to find it easily.
Old May 23, 2010 | 03:09 PM
dadsexcursion
thats what i always said if you nee refrig it is leaking. I was going to use a dye can next. i will look around where you suggest. thanks
