292 diffs
Old May 19, 2010 | 05:13 PM
69supercj's Avatar
69supercj
292 diffs
Found a running 292 on CL the other day but its out of a F800 Truck. Would this be a good motor to replace the 272 thats in my 58 F100 now? I believe it also had a 4 speed behind it. Thanks for any help!!
Old May 19, 2010 | 05:38 PM
312's Avatar
312
be careful its not a 302 or 332 lincoln y.if its a 292 it should be the h.d. engine.it will fit no problem.
Old May 19, 2010 | 08:20 PM
59flatbedford's Avatar
59flatbedford
yea as long as its a 292 it should work fine. it might be a H.D. motor meaning it will have different compression and im not sure what all else (forged crank, rams horns?????)
Old May 19, 2010 | 08:23 PM
fifty-two_f1's Avatar
fifty-two_f1
Why not bore the 272 out to a 292?
Old May 19, 2010 | 08:34 PM
mOROTBREATH's Avatar
mOROTBREATH
Whoa whoa whao whao, what's wrong with the 302/332?
They aren't fords??!?!?!!??
I am interested in a transmission that I suspect only came hooked up to the 302-332 in 1956 and I'm curious to learn as much about those two motors as possible.
Old May 19, 2010 | 11:14 PM
52 Merc's Avatar
52 Merc
The warning is not to say they are bad engines, but to say make sure you're getting what you think you are. Buying a Lincoln Y and thinking you're getting a Ford Y would be like wanting a 351W and someone selling you a 460 instead. If you didn't know the difference, you'd be a bit dissapointed when you got home and things didn't fit like you thought they should.
Old May 20, 2010 | 06:31 AM
3414's Avatar
3414
Usually the 292 was not used in anything much larger than the F700. And that was the HD model, which had a 4 barrel and a governor with low compression. The 302 and 332 also had 4 barrels and governors. One tip, if the distributor has a connection for a tach drive cable it most likely a 302 or 332.
Old May 20, 2010 | 02:23 PM
mOROTBREATH
^^So your saying that let's say--a '56 F600--may have come with a 292 and NOT a 302/332?
The shop manual I have has a chart that describes which trans were stadard and which ones were optional on which trucks..,.
But the freakin manual doesn't go into detail about which ENGINES were available standard/optional on which models.....I'd really like to see something.
Old May 20, 2010 | 02:53 PM
3414's Avatar
3414
302 was usually F700 and up, 332 was usually F750 and up. F600 was 292 MD and 292HD for V8s 58 and later. 56 might have had a 272. Sales literature often listed standard and available engines.
