HELP ! Z bar problem
Old Feb 2, 2003 | 05:48 PM
Crowbar65's Avatar
Crowbar65
Question HELP ! Z bar problem
Hello all!
Another question on the '74 360 into '78 F350 swap I am doing.
I got down to getting the engine ready to pull and found another "little" problem to deal with.
Seems the the Z bar pivot ball is mounted on a 351m/400 specific bracket that bolts to the aft face of the bellhousing, using the engine/bellhousing bolts.
I guess I need an FE specific bracket to go on the 360 bellhousing to make this work.
Are those as hard to find as the rest of the stuff I finally laid hands on?
Would anyone have a fab drawing from which to build one?
Thanks,
Mike
Old Feb 2, 2003 | 07:27 PM
Mike W's Avatar
Mike W
Doesn't the 360 have a threaded hole in the block for the pivot ball like the early 302's have?
Old Feb 2, 2003 | 09:12 PM
Crowbar65's Avatar
Crowbar65
Just went out to look at the engine, and no boss for the stud.
I was hoping the 400 bracket was to adapt the newer block to the FE condition, but nooo...
I design aircraft components, attachments and brackets, etc. for a living, so it shouldn't be too much of a hassle, just one more than I wanted.
Thanks,
Mike
