Ignition Switch Help!!!!
Old May 18, 2010 | 08:17 PM
shaw4825's Avatar
shaw4825
ok guys i have a 95 F150, and the shift tube broke, so i replaced it. well the idiots who had the truck before me has a zip-wire tie around a switch on the back of the column. it is holding it down where the lever on the column holds it down while in park. Well my key will turn on but not go futher to start. Well i pulled the tie back tight and it would go to start so i put everything back on the dash and next...would not go to start!!!! so i took my column all apart again and the tie is still tight but my ignition will not go to start, can anybody help me??? im about to just get a whole different column but prefer just to fix whatever
