flathead v8 crankcase ventilation ??
Old May 18, 2010 | 06:19 PM
r_reed's Avatar
r_reed
i know the ultimate answer to this is engine rebuild, but that is off until next year. i have a good running eab, 110 Lbs. compression on 7 cylinders, 85Lbs. on 1 cylinder. it starts easily, idles smooth, Oil pressure 44LBS, start up, 18 cruising and drops to 10 at fast idle. i have a "ross" version pcv set up and have eliminated the draft tube, that seems to work fine. my question is about the oil filler cap (breather?). is that supposed to let air into the crankcase? i get puffs of smoke out of the filler cap and see evidence of oil blowing out when i'm hauling up hills at 45mph. i assume it's blowby, is there anything i can do to manage it? can i "t" it into my pcv line? does the draft tube area vent the valve chest ? is air supposed to come up from crankcase to the valve chest and out?? if so, does that passage sometimes get blocked? love the eab but the oily mist hits my engine/exhaust manifold and makes unnec. smoke. apologize for the length of the post. dick r
Old May 18, 2010 | 06:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Modern OEM PCV systems have that tube that goes to the air cleaner housing, outside of the filter, to eliminate exactly what you're seeing. You can certainly do the same, it will at least contain the vapors. It's normal for the PCV to reduce the amount it draws when under load (low vacuum).
Old May 18, 2010 | 07:22 PM
r_reed's Avatar
r_reed
thanks ross, i'm going to try that. right now i'm running the teeny/tiny hot rod chrome air cleaner. will have to look for something different to incorporate a vent tube. happy motoring. dick r
Old May 19, 2010 | 05:53 AM
joedellcarter's Avatar
joedellcarter
Sounds a lot like my Flatty. Smokestack Lightnin'
Old May 19, 2010 | 07:51 AM
ALBUQ F-1's Avatar
ALBUQ F-1
It's hard to find something larger for these, but it's worth it. The little ones have a lot of pressure drop and the small filters also get plugged quickly. If you do run a tube for the vapors, try to incorporate a shield so oily vapor doesn't get right on the paper element. One thought is to use one of those typical Ford plastic "filter" elements that clips into the air filter housing, the ones with a coarse white mesh in them.
Old May 19, 2010 | 01:35 PM
r_reed's Avatar
r_reed
got the idea, ross, will go to the junkyard tomorrow on a scouting trip. when i ran my f-1 in the 1970's i used a carb clamp from and old oil bath cleaner and used two paint can lids for my upper and lower housing. hoping to avoid that this time around. maybe i can cut the clamp off my little cleaner and attach it to a larger cleaner with bigger paper element and vent hook up as you suggested. dick r.
Old May 19, 2010 | 01:38 PM
BlueOvalRage's Avatar
BlueOvalRage
On a slightly different note, 110 lbs. of compression is pretty darn good on a flatty and your oil pressure numbers are good, too. Rather than a full rebuild, you might consider jerking the head off the bank with the 85 lb. jug and checking the valves. If you can get the compression back up in that cylinder with just a little valve work, then a rebuild might not be necessary.
Old May 19, 2010 | 03:10 PM
r_reed's Avatar
r_reed
we were pleasantly surprised at the 110Lb per 7 cyl as well. we got this engine (eab) from a junkyard for $500. after a few "false starts" over old wiring, once it got spark it started and never quit. the head/valve check sounds like a good step. next winter i'll put it on the agenda for my brother in law and i. he does the important stuff, i hand him tools, clean/paint parts. didn't know whether my oil pressure was in the range or not, glad to hear it's at least reasonable for a weekend runabout. will update on my air cleaner project when i get it done. thanks to all for the continuing help. dick r
eallanboggs
2004 - 2008 F150
Dec 20, 2021 06:09 PM
Driver1337
Feb 28, 2017 10:46 AM
bjmayberry2
Jul 17, 2014 09:18 AM
raydav
16
Jun 21, 2014 06:52 AM
4rdnut
Dec 22, 2010 03:28 PM
