help please!!!!!
Old May 18, 2010 | 05:37 PM
Jeffery the first's Avatar
Jeffery the first
Exclamation help please!!!!!
ok so i have a 1992 ford f-150 4x4 5spd with a 302 in it...my problems are as followed
-loud a$$ fan got one from a gm and put it on...still sounds like a huge turbine under my hood
-when i push the clutch in some times even when the truck is hot the rpms jump up and idle high like it has just been cold started...
-exhause leak i put brand new pipes on it this past week and still have a exhaust leak possible a manifold? hear they are tipical in these trucks
-will 2wd f-250 coil springs fit the front of my truck to lift it up a bit higher?
hope to hear some info soon guys and thanks to all who have some wisdom for me lol
Old May 18, 2010 | 07:41 PM
Reddog170's Avatar
Reddog170
Not certian about the springs, the idle control may be going out, My experiance says you may have a cracked exhaust manifold, and with the fan I may try an electric as I do not know if you are going to be able to quiet it down, unless the fan clutch is shot. shaun
