Help 2000 7.3 wont start
Old May 18, 2010 | 04:59 PM
DragnBotm's Avatar
DragnBotm
I installed a HT starter changed the oil and now it wont start. Cranks like a SOB with that new starter but just wont fire over.
Any suggestions. Started before I put the new starter on.
Old May 18, 2010 | 05:32 PM
bren7176's Avatar
bren7176
check the IHOP reservoir for oil, if there is none add oil and try to start.
Old May 18, 2010 | 06:32 PM
DragnBotm's Avatar
DragnBotm
put old starter back in and it fired up.
Old May 18, 2010 | 06:40 PM
clintbonnie's Avatar
clintbonnie
My 1st thought would be the new starter is rotating backwards from the old one.. But that is impossible, I would guess. That is a wried one !!
Old May 18, 2010 | 07:24 PM
Kajtek1's Avatar
Kajtek1
Weird it is.
Back track all the wires you disturb during re-installation.
Old May 18, 2010 | 07:26 PM
F350-6's Avatar
F350-6
If it started before you did the swap, we'll need more info on how it died, what you've done and checked so far, and things like that. Have you pulled the chip or swapped the CPS yet?
Old May 18, 2010 | 07:39 PM
Nick 99's Avatar
Nick 99
The High Torque starter will draw a lot more current to spin the motor. My guess would be that with the heavier load on the batteries, the voltage is dropping down to a point where the injectors wont fire. Do you have a way to measure the voltage while cranking the motor?
Nick
Old May 18, 2010 | 08:05 PM
gradyc's Avatar
gradyc
wellhead
I tend to agree with Nick.
Old May 18, 2010 | 09:08 PM
bren7176's Avatar
bren7176
I agree with him too
Nick
Old May 19, 2010 | 01:19 AM
DragnBotm's Avatar
DragnBotm
After sleeping on it that is what I am assuming to. Not enough voltage. The problem I am having is the truck has always had a hard start issue since I've owned it and I am trying to narrow thigns down. Just don't know where to start really. It has new GPR and Gp fresh batteries and it is still hard to start. What should I look at next?
Thanks for the help this problem is driving me crazy.
Rich
Old May 19, 2010 | 08:52 AM
Nick 99's Avatar
Nick 99
Do you have a voltmeter?
Does the motor smoke when starting?
What color is the smoke?
What kind of oil are you using?
Is the HPOP full of oil?
Do have a "code" reader?
Are all the battery connections clean and tight?
When was the fuel filter changed?
What outside temps are we talking about?
Does it start okay when motor is warm?
Old May 20, 2010 | 01:51 PM
DragnBotm's Avatar
DragnBotm
ok been a day or so so here goes:
Yes I have a voltmeter.
No smoke
rotella T 15w-40
No code reader
Hpop is full
motor warm starts alright
I had to crank 3 times to get it to start at 50 degrees
Connections are clean and good
changed fuel filter as well
So I took my batteries to Auto Zone had them tested one was ok one was low. Charging the low one up. Alternator tested fine as well.
Any more suggestions?
Old May 22, 2010 | 10:16 AM
DragnBotm's Avatar
DragnBotm
BUMP any suggestions
Old May 22, 2010 | 10:21 AM
clintbonnie
No smoke
rotella T 15w-40
No code reader
Hpop is full
What is the voltage at the batteries while cranking ?
