Letting go...
Old May 18, 2010 | 03:46 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Letting go...
Well people, I'm looking at an '01 Lariet crew cab f-350 single rear wheel with an A/T and 145,000 miles, my question is the tranny seemed to shift a little hard into o/d or maybe quick is the word I'm looking for, I hit 45 or 50 mph or so, it seemed like a solid lock up. I'm just wondering if that's normal. I like the six speed and all, but my knee don't anymore and the wife don't care for it either. Soooo... the '99 is going up for sale.. and I get to start the mods all over again.
Old May 18, 2010 | 03:52 PM
Joelong258's Avatar
Joelong258
Well from 1 to 10 how hard does it shift?
My truck shifts into od normally around 39-45 mph and when it does it can be fairly rough at times but it may be related to the edge i have.
Old May 18, 2010 | 04:09 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Starting out it shifts smooth. Am I mistaking the t/c lock up to the shift into o/d?
Old May 18, 2010 | 04:15 PM
snakedoc's Avatar
snakedoc
at times mine well lock up real hard around 45.
Old May 18, 2010 | 04:20 PM
Brother Les's Avatar
Brother Les
my '01 F-250 Crewcab tranny went South at 108,000.... It was having a lot of trouble shifting from 2nd to 3rd.... Ended up buying a BTS-trans... When 'Brian' from BTS tore into my old tranny, he said that the OD was ate-up the worse than any of the rest of the gears....
A transmission flush may help it out... I tried that on mine when it was shifting bad, but it was too late... One day it shifts fine and the next it was gone gone gone.
Old May 18, 2010 | 04:29 PM
schlepprock250's Avatar
schlepprock250
It sounds like torque converter lock up,not overdrive,I see by your sig.you have a DP-Tuner,I've had mine in about three years,I sent it in for updates and I was talking to Jody and he told me as long as I have had my chip,there was literally thousands of updates that should be applied.Since I got it back in it shifts/runs much better than it did,I'm actually waiting on a response from Jody about tweaking my TC lockup,Maybe you could see if he could lighten it up some,unless it's just time to trade.
Old May 18, 2010 | 06:07 PM
brian42's Avatar
brian42
Veteran: Navy
When I bought my '03 it had 146K on the odometer. The tranny shifted smooth (nothing rough at all) albeit a little mushy.
Old May 18, 2010 | 06:18 PM
Shake-N-Bake's Avatar
Shake-N-Bake
From what I remember of my stock transmission, the gear shifts were somewhat soft and mushy compared to when the TC locked up (around 40mph under light throttle). So what you describe sounds about normal. It's been about 100k miles since my original transmission was rebuilt though, so my memory is a bit fuzzy...
