Hi all; I have a 223ci. with Ford O Matic. I just switched from 3.73 to 3.31, 29in tall tires. I advanced the timing a couple degrees, the truck runs great! I have NO lugging with local driving. It should be about 2500 rpm at 65mph. Going to be on the freeway tomorrow, will report back. The little 223 is stronger than you might think.
Hi all; just reporting back after putting 60 freeway miles on the truck. I drove no faster than 2500 rpm, and it drove like a dream. Happy to also report that she got a trophy for best stock truck. Some very nice folks in Chino Hills. Have a great nite, I sure will.
And we've had this discussion before. First, the tire isn't round with weight sitting on it - it's an oval. So you won't get an accurate diameter measurement (within an inch) on it. And the error is multiplied by 3.14 when you mathematize it. It's a significant error.
You quoted what I said.....
Originally Posted by HT32BSX115
True if you just use the diameter of the tire.....
But measuring the "rolling" radius (center of the axle-to-ground.....and then "doing the math") is virtually the same as measuring the "roll-out" circumference.
I thought I said that when I said you have to measure the ROLLING RADIUS (which DOES account for weight on the tire.....um, it's the same thing as measuring the rolling circumference....there's no additional error when multiplying by a constant either)
And I also agree that it's probably easier for some to just put a tape measure next to the tire and mark it with piece of chalk.......
BUT, you're still gonna have to do some math!!.....Thankfully, it's just multiplication and division...
