94 bronc-0-swap
Old May 17, 2010 | 05:23 PM
harvy's Avatar
harvy
94 bronc-0-swap
i swapped a 302 from the 70's in to a 1994 bronco. it's all good as far as the engine is concerned but the trans will not shift right (shifts late). can i hook up the ecu up to the motor some how for a rpm reference to the trans? would that work?
p.s. don't bring up smog or any bs on why i did it. it's done and runnin' please help me take it from here.
thanks, harvy
Old May 17, 2010 | 09:48 PM
Conanski's Avatar
Conanski
So you have the EFI installed on this motor?
Old May 18, 2010 | 02:06 AM
harvy's Avatar
harvy
no, not an efi motor. had a gas carb on it and now it has a propane setup
this should've gone in the tranny section
Old May 18, 2010 | 11:03 AM
Kemicalburns's Avatar
Kemicalburns
Your SOL with out that ecu and efi. thats how the tranny gets its info from sensors on the motor and the rear diff. tell me you still have the 8.8 rear diff in there also right!!
Old May 18, 2010 | 12:16 PM
Conanski's Avatar
Conanski
Originally Posted by Kemicalburns
Your SOL
Yep.. you now need to install a non computer controlled transmission or simply put the EFI setup back on the motor.
Old May 18, 2010 | 03:13 PM
85e150's Avatar
85e150
What trans is it? AODE or 4R70W or E4OD?
Trans ID:
http://www.**************/myfiles/transmission.jpg
Stand-alone controllers are available. Not cheap or free, but imo a better bet than a trans swap which may involve a lot of fiddling with things like cross members and DS.
Electronic Performance Products -- Baumann Electronic Controls, LLC
I noticed you are in Costa Mesa? Got a relative in the smog business? You'll never get it registered legally.
Old May 18, 2010 | 04:22 PM
Kemicalburns
yea your rig is now illegal in the State of Cali
