C6 Easy Question (?)
Old Feb 2, 2003 | 01:15 PM
BillyBoB007's Avatar
BillyBoB007
Just found out i have a C6 transmission. As i am not a transmission expert. But i am very mechanically inclined.. The problem ? It will go in reverse , but none of the forward gears. Done checked the filter, looked nice and clean. COuld this be a linkage problem ?
-----> Also , does the neutral switch only have one bolt attaching it to the tranny? (C6) model.
Old Feb 2, 2003 | 06:25 PM
GeneStoner's Avatar
GeneStoner
Your trans is installed backwards.
Old Feb 2, 2003 | 09:02 PM
BillyBoB007
I sense a bit of sarcasm here.
Old Feb 4, 2003 | 07:07 PM
dro man's Avatar
dro man
sounds like the foward clutch must be burnt up which means overhaul. the switch has 2 bolts and i dont see this being a linkage problem but you could get under the truck and shift it by hand to be sure.(careful) dont get run over.
