Sponsored by: Kumho
deceleration vibration
Old May 17, 2010 | 04:52 PM
lulew920's Avatar
lulew920
1998 f-150 4x4 4.6L 116,000 miles or so.
This fiasco started when I noticed a bad vibration in the seats and floor when coasting from 70MPH. So took it home jacked it up found complete tie-rod assembly had excessive play left to right, up and down and front to back. Also found passenger upper ball joint was shot. Last night tore it all apart and replaced inners, outers, pitman arm, idler arm, and gear box cuz I broke it trying to install new pitman arm. Also replaced upper ball joint. Now steering is great and no floating from left to right.
But...Vibration is still in the seats and floor while decelerating from about 70MPH or so. It does it in drive and also in neutral. Upon hitting the brakes it gets 10 times worse.
Truck does not do this while stopped in neutral or park with revving the engine.
4x4 does not work also...front drive shaft turns but wheels do not, could this be related?
Any one have any suggestions on this or have you had the same issue???please help
I have read
Old May 27, 2010 | 07:54 AM
gearloose1's Avatar
gearloose1
Check engine mounts.. transmission mounts too.
Old Jun 6, 2010 | 01:07 PM
lulew920's Avatar
lulew920
Thanks for the post gearloose1 I did check them and followed a hunch and pulled the drive shaft found the rear ujoint was seized. Replaced both since I had it out and wow what a differance.
thanks for your post i will be posting on a 4x4 topic in a few days if you have any input it would be greatly appreciated
DonsF100
Nov 19, 2015 09:00 PM
richard crouse
Apr 5, 2014 10:47 AM
Atc210
Dec 1, 2012 03:50 PM
ford8n47
Nov 12, 2006 06:00 PM
tb40nd
16
Oct 2, 2005 05:10 AM
