I need help asap!!!
Old May 17, 2010 | 02:10 PM
f-2504x4fan's Avatar
f-2504x4fan
I need help asap!!!
Okay I have a 02 f250 powerstroke I have never had this problem before, I was driving it for about 40 to 50 miles and it just stop's no sign no sputtering nothing just stopped, so I changed the cam sensor and I thought it did the job well no it is still stopping, I have checked every fuse and none are bad, and checked relay's I moved them around and no. I had a small oil leak on the ho pump before all this started I fixed the leak. Well now I am stuck I am about to go crazy, to top it off my wives truck transmission is gone
PLEASE SOMEONE HELP
Old May 17, 2010 | 02:24 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Where did you get the CPS to change the one on your truck? Is your oil clean and full? Did it crank after you changed the CPS?
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
Sounds like you know your way around the engine with what you've said.
What comes to my mind first is to check the plug on the IPR valve that is mounted on the bottom of the high pressure pump.
Make sure the tin nut is secure.
Old May 17, 2010 | 02:27 PM
Brother Les's Avatar
Brother Les
It does sound like a CPS problem. You should have been under a 'recall' from Ford. What 'color' did you have in it and what 'color' is the new one. Some people have different reactions with their trucks on these. Did you put any vasoline or sealent on the rubber seal to keep out water, as any moisture will effect it. (mine shut down every time it rained)
Are you able to check for any 'codes' that might have tripped
Welcome to the 7.3 forum. Some more guys and gals will come along with questions and suggestions.
Old May 17, 2010 | 02:30 PM
kirkharrod's Avatar
kirkharrod
FRom the manual:
n
Stalls/Quits: Idle, Acceleration, Cruise, Deceleration
Note:
Perform the following preliminary checks:
n
Engine oil level/quality.
n
Electrical connections.
n
Automatic transmission TCC.
n
ATF level.
n Engine overheating.
If engine restarts after stall, oil return to oil pan may be too slow.
CHANGE oil, if necessary
Starting Concerns: Hard Start/Long Crank/Erratic Start/Erratic Crank, Stall After Start, No
Start/Normal Crank
n
Stalls/Quits: Idle
Note:
n
Check engine oil level.
n
Confirm correct dipstick part number.
n
Check for sufficient clean fuel.
n Check for an intake restriction.
Check Fuel Pump Pressure
Perform KOEO On-Demand Self Test
Perform KOEO Injector Electrical Self Test
Old May 17, 2010 | 03:02 PM
f-2504x4fan
Originally Posted by miller_feed
Welcome to FTE.
Thanks for the welcome. I bought it at auto zone, I changed it after I had repaired the leak and yes is cranked it ran
Old May 17, 2010 | 03:05 PM
f-2504x4fan
Originally Posted by Kwikkordead
Welcome to FTE.
Thanks for the welcome. I wish I knew more. I didnt check the IRP valve
Old May 17, 2010 | 03:11 PM
f-2504x4fan
Thanks for the welcome I did have the recal and I did take it about 10 months ago and the color is Grey I have heard of the black one I haven't tried that one I used sealent but it hasnt rained yet. As soon as I changed the CPS it was fine for about 60 miles and it shut down again. I got the cam code before I changed it and haven't got one since.
Old May 17, 2010 | 03:15 PM
miller_feed
We have had a few members on here that bought one from autozone and they went bad real quick. I would buy one from ford and see if it might work better.
Old May 17, 2010 | 03:16 PM
f-2504x4fan
Originally Posted by kirkharrod
FRom the manual:
n
Note:
n
n
n
n
ATF level.
Start/Normal Crank
n
Stalls/Quits: Idle
Note:
n
n
n
I have gone though all the steps about 3 times all oils are at its operating level clean motor oil, clean tranny oil, power steering oil to its level no leaks, half a tank of clean fuel. I am thinking it might be a wire?
Old May 17, 2010 | 03:22 PM
f-2504x4fan
the last recall I had was for the Speed Control System Modification and that was in march
Old May 17, 2010 | 03:24 PM
Brother Les
If this happened after you installed your new CPS was the plugs snapped tightly together? Sounds like an easy fix.... just have to trace it down.
What kind to truck does your wife have?
Old May 17, 2010 | 03:26 PM
Brother Les
that recall should have nothing to do with your shut off problem.
<!-- / message -->
Old May 17, 2010 | 03:37 PM
f-2504x4fan
Yeah it snapped and fit nice and tight. my wife drives a gmc yukon
Old May 17, 2010 | 03:39 PM
f-2504x4fan
<!-- / message -->
I never had a code for it just got the recall for it.
