53-56 F100 parts
#151
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
Item Condition: AR
Engine: Part suitable for gas truck
#154
Thanks,
Stacey
#155
Stacy, If you just need two inches sections on both sides of the drip rail and two inch section on the front above the windshield, I think I have that much that is good. If you send me your e mail address I'll send you pics of the good parts I have to cut.
#156
Thanks James. I did a more careful measurement. I need about two inches on top of the drip tail on the sides and front, with probably closer to 3 inches on the two front cab corners (above the drip rail). email is staceyhchang at gmail dotcom.
thanks!
Stacey
#157
HI there
I am looking for the chrome drip edge for a 53 1/2 ton deluxe model as well as the shifting linkages for a 3 speed column shift to the transmission (and associated parts) If you have them or know of somewhere that I can connect with them that would be appreciated.
thanks for your time
chris from canada
chris from canada
#158
Chris, I have two sets of the stainless steel drip rail trim but used the best pieces on my 53. They are hard to remove and hard to install without bending them. My shift linkage was rusty and worn so I had to find and buy the best good used set just like you. Give me your e mail address and can send you a couple of phone numbers of guys that may have them. If you can find even a a good partial set of the trim, get back with me and I might be able to send you good pieces to complete the set.
#159
#161
Jesse, I can can send you the 3 speed column assembly and radio head for $220.00 shipped. The two radio heads I have maybe 53-55 ones. I've heard there are very minor differences in them other than the 12 volt change in 56. I'll compare the head units I have with the picture of the radio head in the 56 shop manual and let you know the difference. That price is if you live in the lower 48 states. If you are in Canada I may have to charge a little more for the shipping.
#162
Jim,
I believe the 56 radios had little red triangle marks on the dial in two places, where as the 53-55 dials are all black with white numbers and dashes. Let me know what you have, pictures would be great too.
Also, I plan to fit the 3 speed column shifter to a C6, but I am also wondering if using the fordomatic column would be an easier modification, plus it has the shift window. Do you have one of those?
Jesse
Jesse
