Sponsored by: Real Truck
Need some help from the supercab/longbed crowd
Old May 17, 2010 | 10:12 AM
FoxNotch's Avatar
FoxNotch
Hey guys, I'm interested in some measurements/pictures of the factory parking brake cable setup, as well as the driveshaft and hanger setup on a longbed/supercab truck. Mine is a 5.4 if that makes a difference on the driveshaft, but I'm not sure.
I would really appreciate any help here,
Matt
Old May 17, 2010 | 11:14 AM
DAVE67FD's Avatar
DAVE67FD
What is your intent with these items.
I can get some measurements but will need more specifics of what your looking for.
Where do you need the measurements from? specifically.
Old May 17, 2010 | 11:26 AM
krejci.mike's Avatar
krejci.mike
I can do that when I get home from work. I have the 7.3 diesel though
Old May 17, 2010 | 11:55 AM
FoxNotch's Avatar
FoxNotch
I extended my truck (used to be a shortbed), and for now I just have a shortened crewcab/lb driveshaft and a makeshift brake cable, but I want to get factory stuff eventually.
I particular, I need measurements of each segment of parking brake cable under the cab (there's a few pieces), and a picture would be great.
As for the driveshaft, I'm really just looking for a picture of how the hanger bearing is set up (if it even has one... are they one or two pieces?).
Thank you.
Old May 17, 2010 | 03:42 PM
DAVE67FD's Avatar
DAVE67FD
It is a 2 piece shaft. The carrier bearing bracket is mounted to the cab crossmember. This is aprox. 29" from the trans. flange. You will have to probably inquire with Ford or possibly parts guy "Ed" on the correct bracket p/n as well as the shafts and bearing. Ill have to assume you have a 4x4 truck.
Old May 17, 2010 | 04:09 PM
FoxNotch's Avatar
FoxNotch
Yep, 4x4.... I should have mentioned that.
Old May 18, 2010 | 10:58 PM
FoxNotch's Avatar
FoxNotch
hey you guys didn't quit on me did ya?
Old Jun 8, 2010 | 02:34 PM
FoxNotch's Avatar
FoxNotch
Anyone? I want to get to the bottom of this.
Old Jun 22, 2010 | 05:30 PM
FoxNotch's Avatar
FoxNotch
Bueller? Bueller?
Old Jun 23, 2010 | 11:01 AM
benspeedbarn's Avatar
benspeedbarn
Well, The front, and rear ebrake cables are all the same. Only the Intermediate(center) one changes based on cab/bed configuration. Here are the part numbers, and lengths for the intermediate cable options. Sorry I can't correlate them to configurations. That's all I got, hope it helps.
CARQUEST Brake Products 68954 $91.57 $50.07 45% 85-7/8" LENGTH - PREMIUM
CARQUEST Brake Products 68955 $31.04 $16.34 47% 83 5/8" LENGTH - PREMIUM
CARQUEST Brake Products 68956 $29.55 $15.83 46% 69-1/4" LENGTH - PREMIUM
CARQUEST Brake Products 68957 $31.04 $16.34 47% 64-5/16" LENGTH - PREMIUM
CARQUEST Brake Products 68958 $36.28 $19.92 45% 67-3/8" LENGTH - PREMIUM
CARQUEST Brake Products 68959 $62.10 $33.83 46% 91-1/4" LENGTH - PREMIUM
CARQUEST Brake Products 68960 $57.57 $31.29 46% 88 1/4" LENGTH - PREMIUM
CARQUEST Brake Products 68962 $60.20 $32.76 46% 126-15/16" LENGTH - PREMIUM
Old Jun 23, 2010 | 12:55 PM
FoxNotch's Avatar
FoxNotch
That's the method I used to get what I thought was the right cable. I agree with you that is seems the front and rear cables are the same in every truck, but it still doesn't match up.
I'm gonna shoot outside and measure up what I have/need.
Thanks for the input.
Edit: It seems that CARQUEST Brake Products 68957 $31.04 $16.34 47% 64-5/16" LENGTH - PREMIUM
is what I need. I must have messed up while ordering last time.
Do you know offhand what the wheelbase is on a supercab/longbed truck?
Thank you.
Old Jun 23, 2010 | 01:34 PM
JonathanN's Avatar
JonathanN
Explain again what you're looking for and I'll try to get some pictures and/or measurements for you...
Old Jun 23, 2010 | 01:45 PM
5.4f250sd's Avatar
5.4f250sd
I too will try to help but I need to know exactly what you are looking for and how to post pics!!!!!
Old Jun 23, 2010 | 03:55 PM
FoxNotch's Avatar
FoxNotch
In terms of pictures I'm looking for a picture of the entire driveshaft, and the hanger assembly. Measurements of each shaft would be awesome as well.
5.4f250sd if you want to, email the pictures to me and I'll be happy to post them up for future reference. My email is mmccloskey1@iona.edu
Thanks!
Old Jun 23, 2010 | 04:20 PM
5.4f250sd's Avatar
5.4f250sd
Sounds good it is raining here in my neck of the woods so it will have to wait till tomorrow. That shouldn't be a problem.
