Questions
Old May 16, 2010 | 06:16 PM
krommag's Avatar
krommag
Questions
I have some Question, I have an 04 psd manual trans,73k on her,its running great but here are some question
1) i had the head gasket done at 58k what shoould i look for next
2) i want to update the radio with a sat/nav system which one should i get
3) can i jump start another car, if so how can i do that
thanks for the help
Old May 16, 2010 | 06:33 PM
Maxium4x4's Avatar
Maxium4x4
thanks for the help
1) Let me get my crystal ball first, then I will let you know.
2) I just plug my Magellan in the power outlet, you'll have to find someone else to answer that one.
3) Positive to positive, negative to ground. Hook the dead battery positive first, then positive on the start vehicle. Hook negative to the start vehicle then find a ground spot on the dead vehicle. Frame or clean engine bolt will work.
No frozen or cracked batteries should ever be jumped, if you have a questionable situation do not attempt to jump another vehicle.
Old May 16, 2010 | 06:45 PM
Sarge261's Avatar
Sarge261
I have a Kenwood DNX 5120, I have had it for 2 years and I love it. Wish I would have put it in when the truck was new, but I do kinda miss the 6 disc. in dash changer.
I will say that I listen to Satalite radio most of the time though.
As far s the other stuff, Max has you coverd.
I wish I had a crystal ball too Max, my cutomers always ask "so what do you think is gonna happen next" I wish I knew
Old May 16, 2010 | 08:06 PM
cheezit's Avatar
cheezit
I aways awnser I dont know but I bet it wont be any cheeper next time.
