1978 - 1996 Big Bronco
help please
Old May 16, 2010 | 01:46 PM
scottyc66's Avatar
scottyc66
help please
ok,so a coupl years ago my dad was driving my 1978 bronco down the road and said he heard a "pop" sound and then the truck went dead...he seems to think its the carb,can anyone shed some light please?
Old May 16, 2010 | 01:55 PM
g_k50's Avatar
g_k50
A pop that can be heard could be the head gasket. That would be the worst case scenario.
Does the truck run now?
Oh, yeah, what's the specifications on your truck?
Old May 16, 2010 | 02:02 PM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate info we can.
That is a pretty vague description of the problem. I am going to assume it will no longer start. Does it crank? Any visible leaks since it died? If you are certain you have the ignition trilogy (Air, fuel, heat/spark) and it still won't start you are probably dealing with a mechanical failure.
Any indication as to where in the truck this alleged "pop" came from?
Old May 16, 2010 | 02:05 PM
scottyc66's Avatar
scottyc66
yes the truck runs now if you pour fuel down the top of the carb,but other then that it wont run what so ever.
Old May 16, 2010 | 02:13 PM
g_k50's Avatar
g_k50
Remove fuel line from carb, connect a hose to the fuel line into a suitable container, turn over engine to check for full fuel flow from fuel pump.
Old May 16, 2010 | 02:16 PM
scottyc66's Avatar
scottyc66
ok,i just tried that,and fuel was coming out of the fuel line no problem.
Old May 16, 2010 | 02:21 PM
g_k50's Avatar
g_k50
Rebuild the carb.
Old May 16, 2010 | 02:45 PM
scottyc66's Avatar
scottyc66
alright ill try that,thank you,ill post if it works or not
Old May 17, 2010 | 11:02 AM
Kemicalburns's Avatar
Kemicalburns
sounds like the powervalve on the carb popped. is it a holley on there?
christieperalez
Jun 30, 2013 02:38 PM
wdglide
Dec 14, 2012 08:52 PM
dustybumpers
Maryland Chapter
Mar 15, 2012 06:57 PM
dustybumpers
Maryland Chapter
Feb 23, 2012 05:58 PM
MustangGT221
General Automotive Discussion
19
Aug 3, 2005 10:33 PM
