Transfer case shifter linkage
Old May 15, 2010 | 09:21 AM
rosesrfree4u's Avatar
rosesrfree4u
Hi all,
This is my first time posting here although I often search and find good info. I know this topic is a rehash but I couldn't find the info I needed. I have a 1993 f-250 with manual transfer case shifter. The shifter works as long as you pull up on the shifter handle when changing between 2wd and 4wd, (i haven't been brave enough to try 4L yet) but there's nothing holding the linkage onto the guide track so it really doesn't work well enough for my wife to use it. I would like to know what the guide or bushing assembly is supposed to look like so I can weld something up.
Pictures worth a 1000 words so hopefully these flicker links work so you can see what I'm working with.
151_5181_comp on Flickr - Photo Sharing!
151_5184_comp on Flickr - Photo Sharing!
If anyone has a working transfer shifter, I would be super grateful if you would post or link an image of the guide assembly!
Old May 15, 2010 | 09:43 AM
Slip ford man's Avatar
Slip ford man
Look's like everything is there, trace it up to where it bolts to shifter arm. It may have loosened and turned some part of 360 degrees, or lost the nut that holds it to the case. When done, spray it with ATF now and then
Wyowanderer
Ford Truck Parts for Sale
May 29, 2015 07:20 AM
96broncoXlt
1978 - 1996 Big Bronco
Jul 29, 2012 10:15 AM
surferaw
6.7L Power Stroke Diesel
13
Jul 29, 2011 09:39 AM
cjray03
19
Nov 4, 2010 10:49 PM
dreuter
Jan 7, 2010 11:12 PM
