radio/windows wont work problem
Old May 14, 2010 | 06:58 PM
tpr's Avatar
tpr
I have a 2005 Ford super crew, the radio/windows and rear window wont work. I have check all fuses and all seem to be fine, any suggestions would be appreciated
Old May 17, 2010 | 07:38 PM
pidaster's Avatar
pidaster
Check your relay for power windows. Swap it with another of the same and see if it works.
Old May 17, 2010 | 08:02 PM
tpr's Avatar
tpr
I already did that and it did work like that either?
Old May 17, 2010 | 11:48 PM
screwy's Avatar
screwy
Power saver relay, runs both your windows and radio.
Old May 18, 2010 | 02:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
take a voltmeter to those fuses...or just replace them. sometimes they blow and will still look perfectly fine.
the battery saver relay is integrated into the Inst. Cluster. so if that is fubar'ed...you have to replace the Inst. Cluster
John Sandru
Jul 7, 2015 10:29 AM
scotttahoe
Oct 9, 2013 05:52 PM
scotttahoe
Oct 9, 2013 05:38 PM
BoatPuller88
Jun 4, 2013 08:10 PM
Mr Powerstroke
Dec 9, 2009 04:02 PM
