A/C problem
Old May 14, 2010 | 03:49 PM
robs01f250's Avatar
robs01f250
A/C problem
just recently my air conditioning started defaulting to defrost. I found the problem and it was one of the vacuum lines coming from the hub had been disconnected. So that fixed it, but now it is defaulting to defrost and will come out of the vents if i us the ESOF and turn it to 4wd high. I can then turn 4wd off and it will stay on the vents until i turn the ac off then i have to go through the whole spill just to get it to come out of the vents. Any ideas??
Old May 14, 2010 | 07:57 PM
megawatt00's Avatar
megawatt00
It sounds like there is a vaccume leak within the hub Rob might be a god time to pull them clean them up grease them and IIRC there is a oring or two in there
