PLEASE HELP!!! Alternator replacement
Old Feb 1, 2003 | 05:51 PM
K-Town Ford's Avatar
K-Town Ford
I have a 1993 Ford F-150 4X4 with the 300 6 Cyl.
My alternator went out and I need step by step on how to remove it.
Any help would greatly be appreciated.
Thank You
Old Feb 1, 2003 | 06:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Your post was moved here from the Garage forum.
The first thing you need for your truck b4 you do anything else is buy a shop manual for it. The Haynes or Chilton's manuals will probably serve you well.
The process is too long for me to try to provide here. Use the manual or someone else may want to type it all in. The manual has diagrams in it.
Old Feb 1, 2003 | 08:14 PM
K-Town Ford
Thank You....Does anyone know of any "online" manuals out there?
Old Feb 1, 2003 | 09:38 PM
PATS2002's Avatar
PATS2002
Try this but go shoot the 16 bucks and buy a haynes manual
Old Feb 1, 2003 | 10:38 PM
lexluthr69's Avatar
lexluthr69
I agree with Pats, go buy the Haynes manual. Not only will it tell ya exactly how to replace it, but it'll give ya the extra information on what is going on that you will hopefully appreciae, as well as pretty pictures. If you decide not to go that route, just loosen the idle tensioner pulley bolt till it pops back (relieves tension) and then remove alternator bolts, remove alternator and/or regulator plugs from sockets on alternator, remove alternator, and then reverse for installation.
Luke
Old Feb 2, 2003 | 01:31 AM
1pump's Avatar
1pump
Just make sure you disconnect the battery first.
