"Whistling" 2005 F150 ext.cab
Old 01-01-2011, 12:06 AM
10bender24's Avatar
10bender24
10bender24 is offline
At 30 degrees or colder and between 55 to 70 mph the truck whistles.. Not sure what is causing it but it is annoying.. Any other people notice this..
Old 01-01-2011, 08:23 AM
deezel's Avatar
deezel
deezel is offline
I also have high pitched whistle in cold weather,thanks for replies in advance.
Old 01-01-2011, 09:46 AM
celjel's Avatar
celjel
celjel is offline
Do you have the sirius antenna from the factory on the roof? My 06 does that and the 08 f-350 I had did the same thing and I belive it is the antenna that causes it.
Old 01-01-2011, 10:17 AM
danorules's Avatar
danorules
danorules is offline
i have not experienced this on the fords, but the kenworth i drove for work would do the same thing. it turned out to be the windshield gasket shrinking in the cold, thus leaving a gap between the gasket and the body, resulting in a whistle. i dont know if this is a possibility on the 150, but it could help with the search for the whistle.
Old 01-01-2011, 10:58 AM
Smokey01's Avatar
Smokey01
Smokey01 is offline
I have an 08 and it has been whistling since it has gotten cold too
Old 01-01-2011, 02:19 PM
jdrahush's Avatar
jdrahush
jdrahush is offline
I had a whistle on my old truck during the cold temperatures. I kept trying to track it down and finally figured out it was RPM dependent not speed. At the end of it all it turned out to be my alternator. I replaced it and the whistle went away. I almost didn't replaced it because it was working fine, but it finally got to the point where it was really annoying me. Not saying this is your problem but it's worth a look.
Old 01-01-2011, 02:34 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
2004 xlt 5.4 is offline
Had some problem new alt. fixed problem
There used to be a TBS on here about the problem
Old 01-01-2011, 04:31 PM
pelphrey's Avatar
pelphrey
pelphrey is offline
I got a 04 supercab no external antenna's except the am/fm antenna and noticed this the other day at a constant speed, once I dropped a few MPH it went away and haven't heard it since. Thanks for the heads up, I'll pay attention to the atlernator, NEVER would have thought that!
91dirtydiesel
07-05-2015 12:14 PM
Unrealo4
6.7L Power Stroke Diesel
35
03-23-2015 12:28 PM
Albert Sanchez
1983 - 2012 Ranger & B-Series
05-11-2014 06:37 PM
pinger
1999 to 2016 Super Duty
03-05-2014 08:57 AM
AirSmitty
Offroad & 4x4
11-29-2004 05:08 AM
Quick Reply: "Whistling" 2005 F150 ext.cab
