Tires
Old May 12, 2010 | 06:53 PM
49 Ford F-1's Avatar
49 Ford F-1
Tires
Where can I get some OEM looking tires for my 49 F-1? Also what is better for ride and comfort radial or bias tires? I going to go with 15in wheels bc the tires are cheeper. I want OEM tread and size. I think the tires came solid black with no written on them.
Old May 12, 2010 | 08:50 PM
Julies Cool F1's Avatar
Julies Cool F1
Try Coker, Universal or Lucas.
Coker Tire - Your Source for Antique Tires and Wheels
Home page
Lucas Classic & Vintage Tires
Old May 12, 2010 | 09:08 PM
49 Ford F-1
I have looked at Coker tires, but they are very expensive. I had found a company that had the tires for my truck looked the same as the Coker one, but were about 50 bucks cheaper per tire. I just can't remimber the company name.
Old May 12, 2010 | 09:36 PM
48ATOY's Avatar
48ATOY
I got tires from miller tire
www.millertire.com
Joe
Old May 13, 2010 | 12:23 AM
51PanelMan's Avatar
51PanelMan
Radials are supposed to provide a better ride than biasply tires. They now make radials to look like biasply tires.
Old May 13, 2010 | 12:12 PM
51f1truck's Avatar
51f1truck
I debated for months on bias ply versus radials. The bias ply do look more original due to the thinner cross section. For the same diameter, radials will have a wider profile.
I have only been to a few "true antique car shows" and still find many antique vehicles with bias ply and I have asked the owners about them. Most said they had no issues with the bias ply and drive often. Below is an article I found that seemed to approach this question with a little more objectivity.
A Tale of Two Tires
For the record... I chose radials. I tried to locate a radial with a similar overal diameter as the originals but did limit the section width. A large section width on the front tires can make turning more difficult at low speeds.
Also below is a link I used to make some comparisons on final tire diameter (sidewall aspect ratio also impacts final diameter) and its impact on tire revs at a given speed.
Tire Dimensions Made Simple - Discount Tire
Let me know what you decide and why ...
Fred
Old May 13, 2010 | 02:37 PM
48ATOY's Avatar
48ATOY
Remember a skinny bias tire on the front
is alot easier to turn in parking lots
NO power steering
Joe
Old May 13, 2010 | 07:38 PM
49 Ford F-1
Well I'm going with radials. To me it just seams like the correct one to put on my truck. Now do I need to go with 15 or 16 in rims? I would like to go with solid black walls with no writing on them. Coker said go with 16, but the price per tire is $211 ouch. In 49 did these trucks come with whitewalls or did they come with backwalls?
Old May 13, 2010 | 09:51 PM
jb50F1's Avatar
jb50F1
I can't tell you for sure but all of the original advertisements from 1950 that I have seen and the 1950 owners manual all show only blackwalls.
Old May 13, 2010 | 10:21 PM
49 Ford F-1
ok thanks man did you keep the oem 16s on your truck? if so where did you get your tires from?
Old May 13, 2010 | 10:48 PM
jb50F1's Avatar
jb50F1
I kept the 6.00X16 bias plys. The tires now need to be replaced due to age rather than wear. I'm still looking for something reasonable. I have Nankang on there now but I don't think they are made anymore.
Old May 13, 2010 | 11:26 PM
49 Ford F-1
I talked to people today about tires for my truck, and one told me to talk to Diamond back tire. He told me their prices are better than Coker, and the tires are just as good. I'm going to call Diamond back in the morning and I'll let you know if the prices are better than Coker.
Old May 14, 2010 | 09:01 AM
49 Ford F-1
I just talked to diamond back tire and they are cheeper for the same tire than coker 211 to around 160. that is a big difference.
Old May 14, 2010 | 07:52 PM
1oldtimer's Avatar
1oldtimer
here's a list of radial and bias companies:
bias
kelsey tire
universal
Light Truck Bias Ply Tires
radial
Diamond Back Classic Radial Tires
White wall candy store
the whitewall candy store carries diamond back tires also........i have some on my '47 ford (16's).
Old May 14, 2010 | 08:28 PM
48ATOY's Avatar
48ATOY
I just got a new miller tire catalog with prices
16-600---90.00/with tube?
16-650----100.00/125.00
16-750--125.00
Joe
