Master cylinder
Old May 12, 2010 | 08:55 AM
jmikeyj4's Avatar
jmikeyj4
Master cylinder
what would be the signs of a bad master cylinder?
Old May 12, 2010 | 07:32 PM
4x4 Bart's Avatar
4x4 Bart
Press firm on the pedal then slowly ease up. If the pedal starts to fall to the floor as you ease up, you need a new master cyl.
Leaking at or into the booster.
Variable pedal height when you first apply the brakes.
Old May 13, 2010 | 02:21 PM
JetMech07's Avatar
JetMech07
if you do find out its bad and you can afford it, go ahead and change out pwr booster too at the same time! You can get both as a complete set for a little less too. If ones bad the other is probably close to it too.
