technical questions
Old May 11, 2010 | 09:54 PM
frdf250's Avatar
frdf250
technical questions
Just got my turbo out, thanks to all the help on the stubborn bolt. (6 point socket worked with ALOT of PB blaster)
But heres the deal, got the exaust housing seperated. was a little curious first time i ever pulled a turbo apart and found out how the wastegate worked.
im wondering if the wastegate closes that hole up in the exaust housing, or if it opens it. if it opens it...in order to dissable it wouldnt i just be able to get a freezer plug and stuff it in that hole and take the wastegate off completly?
sorry if that dosent make sense.
Old May 11, 2010 | 10:12 PM
nhill2090's Avatar
nhill2090
the wastegate opens it when the spring setting inside of the wastegate head sees enough boost to move the rod. That is where it sends excess boost pressure
oh and by the way, the whole reason it is set up like this is to protect the turbo from an overboost condition. you can modify anything you want, but sometimes there are consequences
Old May 11, 2010 | 10:29 PM
frdf250's Avatar
frdf250
yea i realize that, just have been chasing after a boost issue for a long time and a van turbo is in the works ne way. so what i am saying is ok to do...with consequences?
Old May 11, 2010 | 10:46 PM
nhill2090's Avatar
nhill2090
only thing it would effect is if you exceed 26 or so lbs of boost on a regular basis, your stock turbo will not last overly long
Old May 11, 2010 | 10:50 PM
frdf250's Avatar
frdf250
sounds good man thanks. i appreciate the quick responses. reps sent
joeyd61
Dec 9, 2011 01:27 PM
radjcw5
Sep 20, 2011 12:21 PM
RMBC Freeride
Oct 10, 2009 10:51 PM
kennedyford
28
Jul 27, 2005 10:27 AM
Don Z
49
Apr 29, 2005 06:36 AM
