Temp switch
Old May 11, 2010 | 09:08 PM
pauljackmax610's Avatar
pauljackmax610
Temp switch
Hello all I'm gonna do my temp switch tomorrow and was wondering is it able to break easy as say the glowplugs? I'll spray it with pb blaster but what I'm asking is will it come off easy or will it break? I'm just worried and also what size socket is it? Thanks for the help
Old May 11, 2010 | 09:10 PM
JamesHajek's Avatar
JamesHajek
Excuse my ignorance but what do you mean by temp switch?
Old May 11, 2010 | 09:20 PM
pauljackmax610
It's the sensor that's on the water pump it tells you if your running hot or not all my other gauges work except the temp gauge so Im thinking it's the sensor
Old May 11, 2010 | 09:23 PM
JamesHajek's Avatar
JamesHajek
OHHHH. The Temp sending unit! Mine wasn't hard to do back in December. Just a quick switch. I forget what size though. Just pop the plug on top and swap it out.
Old May 11, 2010 | 09:27 PM
pauljackmax610
Thanks I was just worried it'll break of in there do you happen to know what size socket you used?
Old May 11, 2010 | 09:29 PM
pauljackmax610
James this may be a stupid question but did it just stop working someone told me it may not be bad but it just runs cold I don't think so to that I mean it's just laying. Down the needle that is thanks Paul
Old May 11, 2010 | 09:30 PM
JamesHajek's Avatar
JamesHajek
I can't remember right now, Sorry.
Old May 11, 2010 | 09:32 PM
JamesHajek's Avatar
JamesHajek
I swapped mine just for reassurance. I knew my stat was toast and the heat in the cab wasn't getting hot and the gauge barely reached the NORMAL range. For the extra 10 bucks or whatever it was, i swapped out the sender too. Just for assurance. There is a way to test the sender if you want... I have the instructions sitting right here if you want to go through it. By the way, there are no stupid questions on here, were here to help.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old May 11, 2010 | 09:40 PM
pauljackmax610
With the thermostat swap is it in the same position as say a small block chevy? And if I change that too I always worry about breaking bolts
Old May 11, 2010 | 09:47 PM
JamesHajek's Avatar
JamesHajek
Idk, my old sb chev had warning lights, not temp gauges. When i swapped the stat and sender, my gauge needle now sits at R when warmed up and creeps into the M when pushin hard. Keep in mind if your problem is the stat and not the sender, fixing the sender wont do anything. I broke a bolt in my thermostat housing. It happens. Nothing you can do about it.
Old May 11, 2010 | 09:49 PM
pauljackmax610
Mind if I ask you another question what's the ccv mod everyone does it seems?
Old May 11, 2010 | 09:54 PM
JamesHajek's Avatar
JamesHajek
It is a CrankCase Vent. Basically you take the doghouse that sits on top of your drivers side valve cover and goes up into your intake system, turn it around and vent all the oil vapors out of the intake and run a hose to the back of your truck. Then you just plug the hole in the aluminum piece of your intake system and call it good.
Old May 11, 2010 | 10:02 PM
pauljackmax610
So the doghouse on the valvecover I spin that around and get extra lenght of hose but what do I use for the plug and is it honestly worth doing?
Old May 11, 2010 | 10:04 PM
JamesHajek's Avatar
JamesHajek
I haven't done it, I figured its not worth the trouble right now. For the plug, im not sure.. probably just a freeze plug or maybe just jb weld a piece of metal to the outside of it. just make sure its sealed up.
Old May 11, 2010 | 10:11 PM
pauljackmax610
I appreciate the help is there any other simple mods I can do to make it run better? I did the intake allready
