I need help. Elec is my weak suit...and this is my first diesel
2000 E350 extended cargo van(7.3).
Water/fuel drain valve leaked.
Disconnected both batt ground and proceded to R&R valve. First tried to get to it from the front and disconnected a lot of the connector/harnesses. That didn't work so I removed the turbo and went in from the back and got the valve replaced. Everything went smoothly from there. Went to re-attach the grounds and got some low amp sparks. Made sure all lights and doors were closed and still got sparks.
I'm pretty sure I got the solenoids on top connected right cuz I put wire ties on one set. Found one connector in front that wasn't connected. It had a gray and a gray with red stripe wires coming out of it with an 8" lead on the passenger half coming from the bundle of wire looms just under the cowling.
I don't think that's important at the moment. I'm mostly scared to connect ground and try to trace down the draw in case it burns out some sensitive electronic stuff.
jtybt Hello, I was cruising the forum and saw your post. Glad you got it going.
I stopped by to invite you over to FTE's 1999-2003 7.3 forum.
There are alot of guys there really know the 7.3 systems inside out. If you get a chance stop by and say hello.1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
I'm new to diesels...and to all this electronic thig-a-ma-bobs so I'll be needing loooots of help. Just trying to get all the little things working right is a PITA.
