95' 4R70W switch replacement
Old May 11, 2010 | 05:25 PM
midnightmike's Avatar
midnightmike
The trans I just bought has fluid insde the RH switch near the pan . I assume this multi pin switch is part of the computer system. It is near the rear and I think it needs replacing. Since I will have the pan off to do filter change I plan to replace it if needed. How do I do that? Thank You
